(0)| 3/15/2007 8:55 PM | |
Posts: 3149 Rating:
Hi which WinCC flex version are you using? WHAT are you changing - perhaps you can attach some screenshots with your problem or a small testproject? nemo |
| 3/16/2007 2:09 PM | |
Posts: 3149 Rating:
Hi this is really a quite strange behaviour...which Panel (or PC-RT) do you use? please have a try with the following options: - rebuild all if this does not help: - go in WinCC flexible to "options > workbench > user interface > layout >reset" and all before has not been successfull: http://support.automation.siemens.com/WW/view/en/24758642 nemo |
