8/9/2013 2:50 AM | |
Joined: 9/27/2006 Last visit: 5/3/2024 Posts: 12257 Rating: (2666) |
Hello Mike; Controlling a MM440 drive over RS-485 implies using the USS protocol (the other option is Profibus-DP, requiring a Profibus-DP master in the S7-1200 and a Profibus-DP slave module on the MM440). Look at the following Application from Siemens and see if it gives you the information you need to proceed: Simple networking and cascading of drives (CE-X8)
What are the differences between USS communications on Sinamics G110 and Micromaster 4?
And the following manual should give you more details on the internals of the USS protocol: Specification: Universal Serial Interface Protocol USS Protocol |
