(2)| 9/26/2013 8:38 PM | |
Joined: 9/27/2006 Last visit: 12/29/2025 Posts: 12477 Rating:
Hello Lamira; The following link points to the Moore 353 controller, level B, operating instructions. The attached extract is a table helping you to determine the appropriate part number for your application. PROCESS AUTOMATION CONTROLLER - Siemens Industry Hope this helps, Daniel Chartier |
| 9/27/2013 12:37 PM | |
Hello Imran; I am not sure about what your last post: do you mean that you are looking to purchase a new model of 353 controller? In this case, I have located from Siemens USA, in Alpharetta, Georgia, showing that they stillmanufacture and sellthe Model 353. There is a presentation brochure in this webpage: https://www.industry.usa.siemens.com/automation/us/en/process-instrumentation-and-analytics/process-instrumentation/brochures/Pages/process-instrumentation-brochures.aspx and here: http://www.industry.usa.siemens.com/automation/us/en/process-instrumentation-and-analytics/process-instrumentation/process-controllers-and-recorders/353-loop-controllers/Pages/353-352p-loop-controllers.aspx Using the information above you should be able to locate the part number and contact information to purchase a new unit. Hope this helps, Daniel Chartier |
| 9/27/2013 1:05 PM | |
Posts: 26 Rating:
Thanks Chartier. I will check them and come back. Thanks again for your support. Regards,
Imran Baig |
| 9/27/2013 4:07 PM | |
Hello imran; I am adding another link, also from Siemens USA, that might prove useful: the global contact list, providing you with local Siemens technical and sales supportnear you (hopefully) by country and city: https://www.automation.siemens.com/aspa_app/contactmenu.aspx?HTTPS=REDIR&ci=yes®id=WW&lang=en&comptcid=o Hope this helps, Daniel Chartier |
| 9/29/2013 10:31 AM | |
Posts: 26 Rating:
Thanks Chartier, i had emailed them and will wait for the feed-back. Regards,
Imran Baig |
