10/21/2013 12:14 PM | |
Posts: 1368 Rating:
Hello Engineering concept, the partial list SSL-ID W#16#xy74 obtains youthe status of the module LEDs. If the H CPUs are in the RUN-REDUNDANT mode, the LED status of all redundant H CPUs is returned. With the INDEX parameter of RDSYST you select the LED you status you want to know. The description of the data record is here http://support.automation.siemens.com/WW/view/de/44240604/0/en from page 732 on. Good Luck, Pittiplatsch |
