6/13/2008 11:14 AM | |
Joined: 10/31/2005 Last visit: 8/2/2024 Posts: 363 Rating:
Hi DJB, as Mario said, you can calculate temperature and pressure compensation if you know formulas. However, I found this very tricky part. You can use approximated formulas for gas flow: Qcomp = Qdp * sqrt(Pcomp * Tcomp) where Pcomp = Pref/Pa for volumetric flow where Pref is designed abs pressure and Pa is actual absoulte pressure from transmitter. Pcomp= Pa/Pref for mass flow. On the other handm for temperature is different: Tcomp = Ta/Tref from volumetric and Tref/Ta for mass flow. I found these formulas as approximation formulaswhich is used by Honeywell SMV multivariable transmitter. You can see more in attached file... I hope this helps AttachmentSFC part of Manual 34-ST-11-14F.pdf (887 Downloads) |
6/13/2008 11:40 AM | |
Posts: 12 Rating:
Thanks Pandiani for ur valuable input . I also got similar formulas from a Siemens source ...see this ...
AttachmentAD353-124r1.pdf (918 Downloads) |
4/23/2014 7:36 AM | |
Posts: 340 Rating:
new question is splittet to calculate mass flow, I get this block for PCS7 |
