(0)| 7/12/2014 5:28 PM | |
Posts: 78 Rating:
Somebady maybe know how need change attach picture code from OBA7 to OBA6. Because OBA6 timer don't have "reference" and don't have Stopwatch :( |
| 7/13/2014 7:10 PM | |
Posts: 5225 Rating:
Hi there, It would have been helpful if you had attached a program segment. I am not sure I understand where the timer gets it reference from. It would be very helpful to know the intention of the code. Referencing a timer in the OBA6 is not a problem.. just limited. For the Stopwatch functionality you will need to work out some of your own coding. But that is possible too. Please have a look at the code attached. Maybe it is the same as what you want. I am however sure the elements you need, you can discover from it. Let us know if it helps.. if not give us some more to work with. Greetings. w AttachmentDesign Idea_OBA6 stopwatch equvalent feeds into TON.zip (225 Downloads) |
