5/31/2015 7:46 AM | |
Posts: 3 Rating: (0) |
Hi, We Connected the RDG 100Kn thermostat with the availability of RDG100KN library block. But the problem remains in the same. The thermostat does not come online as per the document. Error Message : Invalid Subsiderry There is no any change happened when the Thermostat bus line is disconnected from the PXA30 - K11 ( Extension module for KNX). PXC00-U with PX knx firmware downloaded is connected via PXA-30N. Node setup has been done successfully. I'm grateful to you if you could give me an answer for the problem immediately. Best Regards, Carlton
Last edited by: CarltonRdg at: 5/31/2015 8:10:37 AMLast edited by: Min_Moderator at: 6/1/2015 2:19:49 PMNew subject after splitting |
6/1/2015 2:36 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4772 Rating: (123) |
