6/27/2016 7:45 PM | |
Joined: 12/18/2014 Last visit: 9/19/2025 Posts: 36018 Rating:
No, you can not change the pulse length of the TD-key. But you can extend with off delays. The TD-keys give only from pulses, they can not adjust as switches. You can connect the TD-key on a pulse relay, turn on with the first keypress, turn off with the second keypress. |
7/1/2016 8:45 AM | |
Posts: 2930 Rating:
Hi, check the attached example. Hope it helps AttachmentF keys in Web-Server.zip (342 Downloads) |
