(0)| 5/30/2018 9:03 PM | |
Joined: 9/27/2006 Last visit: 1/14/2026 Posts: 12480 Rating:
Hello Islam; This Festo controller seems to be quite old, the documentation found dates from 1997; this is normal if it is a rebranfed S5 PLC. Look at the following Festo document, and the screenshot below. Does this look like the unit you are working with? https://www.festo.com/net/SupportPortal/Files/320522/03-SB50_1997-06_385854d6.pdf As a programming unit Festo suggests a FESTO S-SUB-15-GS-9,, which is now discontinued (since 2007), without any information available. I suggest you contact Festo and ask their p^roduct support if your programming cable is compatible with the SF50-03 control block, and what software is required. Hope this helps, Daniel Chartier |
