4/21/2020 1:31 PM | |
Joined: 5/13/2019 Last visit: 9/3/2023 Posts: 33 Rating: (4) |
Does no one have an idea? I attached the discrete alarm list. |
4/22/2020 3:51 AM | |
Joined: 7/5/2013 Last visit: 8/8/2024 Posts: 3108 Rating: (510) |
Hello icewind, using the Alarm archive you will get an entry for incoming (positive edge) and outgoing (negative edge). In my opinion you cannot modify this behaviour. You can create your own file and write only in case of a positive edge (bit is set). Please refer to With SIMATIC WinCC (TIA Portal) on a panel, how do you access process data in a file via a script?. Regards, Frink |
Pi is exactly three! |
4/22/2020 5:37 PM | |
Thx for your help Frink. I want to find a way another than using a script. How can people save the actions of the operator to datalog in general? the string tag defined before something like "Pump is on". is it possible? |
