(1)| 8/25/2020 12:23 PM | |
Posts: 4 Rating:
Dear community, I tried to configure WLAN settings for IOT2020 following the instructions in the attached file, but then the error appears:"Putty Fatal Error:Network error:Software caused connection abort". When I close the error window, a line in Putty appears and says:"Running /etc/int.d/networking restart is deprecated because it may not enable a gain some interfaces" I tried Putty keepalive and other SSH clients, it didn't work. I look forward to your feedback and therefore your help! Best regards! AttachmentUSB_WIFI.pdf (382 Downloads) |
| 9/4/2020 4:34 PM | |
Joined: 12/12/2016 Last visit: 12/11/2025 Posts: 640 Rating:
Hello, Are you using the latest Image version? What WLAN Stick are you using? Did you change any setting on the eth0 interface which you are connected to? Kind regards! |
