1/15/2021 10:46 PM | |
Joined: 11/20/2017 Last visit: 11/11/2024 Posts: 3 Rating: (0) |
plz,can you help me in PCS7 v9.0 i can not found CPU410-5H at Category of Station400? how i can add it ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/18/2021 07:58:33New subject after splitting |
1/16/2021 10:45 PM | |
I need help in PCS7 v9.0 I can not found CPU410-5H at Category of Station400? how I can add it? |
1/19/2021 1:47 AM | |
Joined: 9/9/2015 Last visit: 10/28/2024 Posts: 728 Rating: (280) |
Hi Tarek, Maybe the UR rack selection is wrong. For CPU410-5H, you can go to Simatic manager->File-> New project wizard -> select any MLFB number that matches the components such as CPU410-xH with xxx, then generates the new multi project out. Later you can double-check the part number in the new project with your current one to compare the differences. Hope it helps. |
Please give me 5 stars Rating if my post is helpful for you. :) |
