2/1/2021 2:58 PM | |
Joined: 10/24/2014 Last visit: 5/16/2024 Posts: 1 Rating: (0) |
I have the same problem. Did you find a solution? |
2/4/2021 10:24 AM | |
Joined: 6/22/2018 Last visit: 12/25/2023 Posts: 109 Rating: (1) |
no, still not unfortunately |
Young passionate programmer ! |
2/5/2021 10:16 AM | |
Joined: 8/3/2009 Last visit: 5/17/2024 Posts: 12970 Rating: (1652)
Hello The Simatic Template Suite Wizard is made for WinCC Unified V16 So you have to install WinCC Unified V16 on your System !!!its not made for Comfort/Advanced. (Here there is only a library available) And also teh Wizard is a Tool that works with TIA Openness, so you have to install this option in your TIA Portal Installation that it has a chance to work... Everything is explained in the FAQ: https://support.industry.siemens.com/cs/ww/en/view/91174767 Bye Murof |
Last edited by: Murof at: 02/05/2021 10:17:10If this Information really helps, you could use the Rate function |
2/9/2021 5:37 PM | |
Hello, Thank you very much, I will try this ! |
