(0)| 7/21/2014 6:56 AM | |
Joined: 8/25/2006 Last visit: 1/20/2026 Posts: 2221 Rating:
Hello. May be you have an old list manual, try to look in thelatestversion: 9: Reference speed (p2000) not set (factory setting value must be modified)!
| 7/21/2014 8:03 AM | |
Posts: 70 Rating:
Hallo too KSN, Ok thanks no.9 fault has now gone, but the fault appears no.8 must be filled with any value, Field characteristic (p50120 ... p50139)? Thanks. |
| 7/21/2014 8:06 AM | |
Posts: 70 Rating:
Here I DC motors without field, because it already has a permanent magnet motors. |
| 7/21/2014 8:18 AM | |
Hello. If your motor with permanent magnet, disable field in p50082=0 and field weakening in p50081=0.
| 7/21/2014 9:00 AM | |
Posts: 70 Rating:
Previously, already set to 0 P50082 and P50081 |
| 9/12/2018 4:54 AM | |
Posts: 112 Rating:
Have you solved your problem, I am having the same issue now. Please share. Thanks Regards Satheesh |
| 1/14/2025 1:43 PM | |
Joined: 4/3/2018 Last visit: 1/16/2026 Posts: 2 Rating:
SAME PROBLEM... ANYBODY FIXED? |
