5/29/2021 5:39 PM | |
Posts: 2 Rating: (0) |
Facing the below message in my SCADA but system is running well and data also saving. "WinCC flexible Runtime has detected a problem with Automation License Manager. Please reinstall Automation License Manager." If I click on “Noted” button of the notification, after some times, it comes again. From the service of PC, I checked and found in "Started" status. Please suggest me a suitable solution to overcome from this problem. AttachmentError message and System Status.pdf (640 Downloads) |
7/20/2021 3:34 PM | |
Joined: 8/3/2009 Last visit: 11/18/2024 Posts: 14181 Rating: (1774)
Hello do you use a newer Win10 Operating System ? If yes then you should also use a newer ALM Version like: https://support.industry.siemens.com/cs/de/en/view/114358 Bye Murof |
