1/21/2022 3:38 PM | |
Joined: 9/27/2006 Last visit: 5/3/2024 Posts: 12257 Rating: (2666)
Hello CevdetC26; I am not a Profibus developper, and most of my documentation on the subject always has pointed to the use of Siemens ASICs for the certified Profibus-DP slaves. For example, look at the following presentation on Profbus slave development from Felser.ch: https://www.felser.ch/papers/FE-TP-0405.pdf I have found one German company that proposes a Profibus slave stack working on a standard MCU, as they show on their webpage: https://www.tmgte.de/en/products/profibus-products/profibus-dp-v1-slave-stack.html PROFIBUS DP V1 Slave Stack with standard MCU
Maybe they can provide some guidance for your project. Hope this helps, Daniel Chartier |
1/24/2022 9:24 AM | |
Joined: 8/31/2021 Last visit: 2/21/2022 Posts: 4 Rating: (0) |
Hi, Thank you sir. It helped a lot. We decided on the MCU and designed our product with it. In this case the best solution would be to use Proficip. The AM1810 Sitara from TI would be a great solution for the new design. I'm droping a link below, in case anyone has the same problem as me. https://www.mouser.com/datasheet/2/405/spry155a-340016.pdf Attachmentspry155a-340016.pdf (460 Downloads) |
Last edited by: CevdetC26 at: 01/24/2022 09:26:21Last edited by: Jen_Moderator at: 01/24/2022 13:55:27Edited text for better reading. Added PDF as an attachment. |
