8/18/2022 1:06 PM | |
Joined: 3/14/2008 Last visit: 9/25/2024 Posts: 2097 Rating: (938)
Not going to work, The measuring browser is added as of PCS7 V8.2. Maybe you can find the BypAct signal in the Process Object View under "Parameter" column. If you can find it, you can export the list but beware you have to do this manually each time.
Last edited by: Oreca at: 08/18/2022 13:08:37If I could help you, you can use the RATE button. Thank you. |
8/19/2022 8:58 AM | |
Joined: 9/27/2014 Last visit: 6/21/2024 Posts: 27 Rating: (0) |
Hello Oreca, What would be the filters on the Process object View? Can you walk me through on this? Regards, mark12 |
