6/10/2022 7:18 PM | |
Joined: 10/17/2017 Last visit: 3/31/2023 Posts: 1 Rating:
Hello, Same thing happened to me. I recompiled the panel software, then downloaded it and a week later the exact same thing happened. Any solution to this problem? I would appreciate if someone gives me an answer. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 06/13/2022 13:07:53Text edited for better reading. Last edited by: Jen_Moderator at: 06/21/2022 15:11:37New subject after splitting |
9/14/2022 11:19 AM | |
Joined: 8/3/2009 Last visit: 9/12/2024 Posts: 13656 Rating:
Hello Nicolás_Quantia you can try to reset all temporary Runtime Data in order to clear any inconsistency: https://support.industry.siemens.com/cs/de/en/view/109778709 But it could also be that your system uses a too big alarm archive. Which HMI Device do you use? which Exact TIA Portal Version and Image Version do you use? Which Settings do you have made at alarm logs (Screenshot would be nice)? Bye Murof |
