9/13/2022 10:22 AM | |
Joined: 10/25/2014 Last visit: 12/6/2022 Posts: 21 Rating: (0) |
Hi Luka Can you clarify the following: Diagnostics in User Program with S7-1200
Last edited by: Ahmad Atiyah at: 09/13/2022 10:23:21Last edited by: Ahmad Atiyah at: 09/13/2022 10:23:54Last edited by: Ahmad Atiyah at: 09/13/2022 10:24:40Last edited by: Jen_Moderator at: 09/14/2022 04:37:16Link optimized. |
9/15/2022 9:59 AM | |
Joined: 4/3/2017 Last visit: 1/27/2024 Posts: 69 Rating: (1) |
How I can do it with quality code of a tag? |
9/16/2022 1:28 PM | |
Joined: 8/3/2009 Last visit: 4/25/2024 Posts: 12867 Rating: (1640)
Hello luka31 the Tag Object has a Qualtiy code property. you can read out for example in a VB Script. simply check the manual: https://support.industry.siemens.com/cs/ww/en/view/109794202/36136718219 https://support.industry.siemens.com/cs/ww/en/view/109794202/36146526603 you also can use C Code fucntions for this. https://support.industry.siemens.com/cs/ww/en/view/109794202/133448886667 Bye Murof |
