3/18/2019 2:22 PM | |
Joined: 8/9/2016 Last visit: 2/20/2024 Posts: 70 Rating: (0) |
please find the attachment step 7 v5.6 AttachmentBackup20190318.zip (260 Downloads) |
3/18/2019 2:48 PM | |
when i enter value 38.0 into the parameter HI, its online value is kind of weird. can you please look into it. |
3/19/2019 5:12 AM | |
Joined: 7/5/2013 Last visit: 4/26/2024 Posts: 3076 Rating: (505) |
Hello Ryan, what does it show, when you use a variable table to monitor the output and set the format to REAL resp. floating?
I guess that is because you (or by default) selected Integer-format to show the values of tags. When you right-click and change the format to Floating, then the IN-value looks kind of weird. @mopS04,
the programming example shows a PIW on the IN of the SCALE-FC. So this should not be a problem. Regards, Frink |
Pi is exactly three! |
