9/15/2022 12:53 PM | |
Joined: 4/24/2006 Last visit: 4/15/2024 Posts: 8610 Rating: (1147)
Hello, Are you using anti-virus program? (Perhaps it will block searching for MAC Addresses) In TIA Portal go to Online Access -> your ethernetcard in PC -> update accessible devices. Do you find any devices? Perhaps you can try to use the program Proneta: PRONETA Basic 3.3 Commissioning and Diagnostics Tool for PROFINET Best regards, Wizard |
9/21/2022 12:35 PM | |
Joined: 8/3/2009 Last visit: 4/18/2024 Posts: 12813 Rating: (1634)
Hello GOG close all online Connections and then usethe download to the panel as here described: https://support.industry.siemens.com/cs/ww/en/view/58522603 If you then still have trouble: https://support.industry.siemens.com/cs/ww/en/view/88633853 and here is plan B if nothing worked: https://support.industry.siemens.com/cs/de/en/view/109740696 Bye Murof |
Last edited by: Murof at: 09/21/2022 12:35:56If this Information really helps, you could use the Rate function |
