9/26/2022 2:37 PM | |
Joined: 8/12/2021 Last visit: 4/16/2024 Posts: 303 Rating: (28) |
Hi Roberto Fonte! Have you tried using error logic in the block call? You can store in an auxiliary flag the Status value to determine which is the first communication error. In this link you can find common error codes and possible solutions.
9/26/2022 4:14 PM | |
Joined: 12/15/2019 Last visit: 4/18/2024 Posts: 20 Rating: (1) |
Hi Swarley92 With Req = false -> status 7004 Witg Req = True -> Status 7005 /7006 is rotate is 500 ms more or less and time to time appears one 8382
9/26/2022 4:30 PM | |
I created , on server on my pc with Modbus Slave and same issue . I attached my program sample also ., thanks
AttachmentTESTE MODBUS.zip (52 Downloads) |
9/26/2022 5:11 PM | |
After , one full day , it works .... I change this Siemens working mode to 103 and it start working . |
