(0)| 12/28/2005 4:24 AM | |
Posts: 8 Rating:
I use CPU226 connect with CP-243-1.CP-243-1 will show SF ( red,flashes). whenpower is failure or off circuit.SF lamp is off whenI download step7-microwin/32 program again.Why does cp-243-1 show SF lampwhenpower is failure oroff circuit braker ? I attach file error code,program and plc configuration. Best Regards, Sittichai AttachmentCP243_Problem.zip (1215 Downloads) |
| 1/20/2023 10:27 PM | |
Joined: 8/12/2021 Last visit: 12/10/2025 Posts: 351 Rating:
Hi sittichai! I hope this help you (40). This CPU and CP is so older and there no t so much info. |
