3/23/2023 2:54 PM | |
Joined: 4/28/2015 Last visit: 3/23/2024 Posts: 3345 Rating: (375)
Hi, yes, this is the problem. The V3.2.2 is not compatible with this firmware used. You may try to boot from Example Image V1.1.1 and update the firmware. After that you can use the IndOS V3.2.2. I can also send the IndOS V2.2 Service Stick, this is compatible with your current firmware. Best regards! |
