Industry Online Support
3/23/2023 8:55 AM | |
Joined: 1/12/2023 Last visit: 5/13/2024 Posts: 19 Rating:
Hello, I had an ipc 427E that worked normally, and after a power cut it didn't want to go, it broke. It was used in production for about 2 years, it is no longer under warranty. In the attachment I have pictures of it disassembled, I tried its source on another ipc and it works normally, so the motherboard is broken. Does anyone know what it could be? How do you give him the order to go? Does anyone know how much a Siemens repair costs? Thank you AttachmentSIMATIC IPC 427E dissasambly.pdf (737 Downloads) |
3/23/2023 11:50 AM | |
Joined: 5/6/2022 Last visit: 7/5/2024 Posts: 429 Rating:
Hi Danielchirita82, The IPC won't boot up or turn on, have you tried doing a restore with the DVDs that come with the IPC? On the other hand, I would recommend that you personally contact Siemens directly in the repair area. I don't know your exact location but I'll share the link here so you can find the one closest to you: "Contacts at Siemens" or maybe with the technical support. Best regards!
4/4/2023 6:55 AM | |
I cannot boot to bios because did not start.. |
