3/19/2023 5:13 AM | |
Joined: 10/29/2018 Last visit: 7/4/2024 Posts: 11 Rating:
Dear All, I want to generate report using this new built in design report "Report Tag Logging RT Curves New" within a time range a and b. I am using Microsoft DT picker v6 sp3 which directly connect to two Tag like "Start Date as string" and "End Date as string" but didn't work. Time format I used like dd/MM/yyyy HH:mm:ss, "dd.MM.yyyy HH:mm:ss" and other guided by Siemens documents. as per this link : https://support.industry.siemens.com/cs/de/en/view/11942662 I am attaching screen shot that I want to do. my purpose is only trend report within specific time range and using specific tag name. specific Tag name is working with "Report Tag Logging RT Curves New" but specific time range is not working. please someone help me how can I solve this. for any further information feel free to contact me in forum. Thanks in advance AttachmentPictures.zip (424 Downloads) |
4/1/2023 11:15 AM | |
Sorry for the mistake.... And issue already solved.... Thanks for reply |
4/16/2023 10:22 AM | |
Hi Sorry for the previous post. Problem it is not solved fully. I used your mentioned date time format but it was not working with start time and end time. I read other post regarding trend and tried many ways but couldn't find any solution. It is work with " All existing data(0)" and "Recently Collected Data (1)" but it is not working with " Data within the specified time range (2)". My client need data within the specified time range of this report "Report Tag Logging RT Curves New" . Can you suggest me how can I solved that . i am attaching my pdl file and time zone setting picture and also report for better understand. My need is only generate Tag logging report within specific time range using " Report Tag Logging RT Curves" layout which one is available in report designer of wincc v7.5 sp3. I think you understood my problem. Thanks in advance best regards AttachmentTrend.zip (432 Downloads) |
