6/23/2023 9:43 AM | |
Joined: 8/3/2009 Last visit: 5/27/2024 Posts: 12984 Rating: (1654)
Hello RonnieBe How do you have set the Limits/Ranges? of the Tag and the Control? Which TIA and WincC Advanced RT Version do you use exactly (with Upd)? If something does not work as expected then try also a reset of the temporary data: https://support.industry.siemens.com/cs/de/en/view/109778709 Bye Murof |
