8/9/2023 7:56 AM | |
Joined: 4/9/2014 Last visit: 7/31/2024 Posts: 8 Rating:
Hello, It is good to install visual studio on same machine that you are useing TIA portal. after that you can check the Demo project from siemens TIA Portal Openness: Introduction and Demo Application And then according to the structure inside in the PDF doccument you can reach different parts of your TIA portal project (online and offline). Every version of TIA portal siemens increase the possibility for openness. You can use thear demo projects that you can download, and find what you want, or you need to dig to do some complex programs in C#. At the end you can automate your job. |
Last edited by: R.Raychev at: 08/09/2023 07:57:37Last edited by: Jen_Moderator at: 08/09/2023 10:35:54Link optimized. |
