3/4/2024 11:57 AM | |
Joined: 1/27/2022 Last visit: 3/5/2024 Posts: 1 Rating:
Hi Position getting lost after power failure in V90 SIEMENS Servo motor : 1FL6042-2AF21-1LB1, servo drive mode1P 6SL3210-5FB10-8UF0 Kindly give a solution Mathesh S ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 03/05/2024 10:55:25New subject after splitting |
3/6/2024 6:03 AM | |
Joined: 4/28/2009 Last visit: 7/17/2024 Posts: 346 Rating:
Hello, your motor has incremental encoder, which doesn't provide actual position, only direction and speed of rotation. So after power failure or switching off and on you need to start referencing procedure or set reference position. Related configuration you find in V-Assistant software or in operating instruction for V90 drive. With regrads Martin |
3/6/2024 5:02 PM | |
Joined: 7/7/2010 Last visit: 7/16/2024 Posts: 14965 Rating:
According to Siemens Industry Mall description for the servo motor's part #, it has a 20-bit absolute encoder.
science guy |
