4/12/2024 7:51 PM | |
Joined: 10/22/2015 Last visit: 4/25/2024 Posts: 1 Rating: (0) |
I also have the same issue with V18 update 2, I can't get a unified project to show up in the web browser, i have local users set and in the project as hmi admisitrator, not luck. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/15/2024 08:12:03New subject after splitting |
4/15/2024 9:34 AM | |
Joined: 1/21/2013 Last visit: 5/2/2024 Posts: 2735 Rating: (443)
Hi Edyer, Make sure your user is a member of the user groups described in the manual. Make sure you do not keep the user management during the download if you want to load some changes there. See the "Runtime Values" section in the Load Preview. Kind regards |
4/15/2024 10:44 AM | |
Joined: 4/26/2012 Last visit: 5/2/2024 Posts: 1520 Rating: (158)
Hello, welcome to the forum. Could you post here an image of the web browser so we can see and check some things? Can you check the IIS status? Can you check the status in Simatic Runtime Manager? When you open the browser, what is the address syntax? good luck. |
Last edited by: rdoliveira at: 04/15/2024 10:47:37image "Always make a backup before and check the best time before testing." |
4/24/2024 7:52 AM | |
Joined: 8/3/2009 Last visit: 4/30/2024 Posts: 12869 Rating: (1643)
Hello Edyer Check also if you have created your CA and Webserver certificate and rerun the Unified Configuration again. Check this FAQ for information https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
