1/8/2019 6:02 PM | |
Joined: 8/31/2005 Last visit: 7/18/2024 Posts: 2198 Rating: (328) |
Install the actual HSP for your TIA Portal version: https://support.industry.siemens.com/cs/ww/en/view/72341852 |
1/8/2019 6:15 PM | |
Joined: 5/12/2006 Last visit: 8/8/2024 Posts: 22338 Rating: (3000)
Hello, 6ES7155-6AA01-0BN0 is never ever in the catalog. This ordernumber is a bundle which contains: 6ES7155-6AU01-0BN0 6ES7193-6PA00-0AA0 6ES7193-6AR00-0AA0 This numbers can be found in the catalog"! For the others you need step7 V15.1, but you can use the same modules with a 0 on the 12th digit https://support.industry.siemens.com/cs/ww/en/view/109757266 https://support.industry.siemens.com/cs/ww/en/view/109751446 Regards Christoph |
1/8/2019 6:28 PM | ||||
Joined: 12/21/2013 Last visit: 8/4/2021 Posts: 11 Rating: (0) |
hii ı bought these product but ı have got TIA portal v 15. how can ı use these product can you help me can you introduce how can ı configurate because ı have got lots of these produt and ı cant retun them . 6ES7155-6AA01-0BN0
1/8/2019 11:23 PM | ||||
Joined: 7/7/2010 Last visit: 8/7/2024 Posts: 15068 Rating: (2404)
This is what is at the very top of the datasheet for that top part #:
I think the tip you are looking for is to start with the "Devices & networks" option open in the project tree. Then type in these part #'s in the search box and they will appear (after hitting the down arrow button to search "forward" in the hardware catalog). First insert the IM, 6ES7155-6AU01-0BN0. Then insert the server module, 6ES7193-6PA00-0AA0. The IM has the BA 2xRJ45 built-in. After that, you can drag in the other 3 modules. NOTE: I performed the hardware configuration using your module part #'s in V15 Update 3.
1/9/2019 7:45 AM | |
ok thanks |
4/24/2024 2:38 PM | |
Joined: 2/11/2015 Last visit: 7/27/2024 Posts: 455 Rating: (34) |
Agree with ChristophD, The reference: 6ES7 155-6AA01-0BN0 is only for purchase. Not will be on Hardware - Catalog. With this reference, we will have the elements: 6ES7155-6AU01-0BN0 6ES7193-6PA00-0AA0 6ES7193-6AR00-0AA0 That, on Hardware Catalog, you'll have the element 6ES7 155-6AU01-0BN0 accessible to configure. |
