7/2/2024 10:53 AM | |
Joined: 3/4/2015 Last visit: 7/17/2024 Posts: 30 Rating: (0) |
I found a similar problem on the forum: https://support.industry.siemens.com/forum/WW/en/posts/loading-scl-code-problem/208984 Could it be that it would be impossible to go online in the SCL block?? And also load compiled changes in the SCL block code from the SCL editor itself?? How to do it? Correct me if I'm wrong. At another facility with a PCS7 system, similar code with SCL blocks is used and they can be edited and loaded from SCL. This makes it possible to track the program online.
7/9/2024 2:04 PM | |
Hi everybody, To this day I can not find a solution to the Previous problem. what can i do ???? best regard
7/10/2024 8:58 AM | |
Joined: 3/13/2015 Last visit: 10/8/2024 Posts: 143 Rating: (40) |
Hi, Good to hear that problem 1 is resolved. I have never experienced problem 2. After some googling i found this thread: Maybe it helps, otherwise its probably time to create a service request. Regards, |
