Industry Online Support
7/9/2009 4:25 PM | |
Joined: 5/28/2008 Last visit: 4/15/2024 Posts: 4505 Rating: (835) |
Hello, 1. Open Hardware config. 2. Insert 3RW44 into the profibus network and assign a profibus address for the softstarter. Then you will found that I/O addresses has been generated for you. And all these I/Os can be read / write from your software. You will found description of these I/Os in the manual in this link, Section 8-7 : Process data and process images. 3. Power up the softstarter and parameterize it using the integrated keys with it or using SIRIUS SOFT STARTER ES 2006 software. This link will show you how to parameterize the softstarter. Begin with the above procedure and if you have question, ask here, and we will help you. Regards, |
Last edited by: Ayman Elotaify at: 7/9/2009 4:26 PMLast edited by: Ayman Elotaify at: 7/9/2009 4:26 PMAyman Elotaify |
