(1)| 4/1/2022 5:24 AM | |
Joined: 3/26/2022 Last visit: 5/31/2025 Posts: 6 Rating:
I have installed Update 2 and the problem continues. Also I have tried to update ALM but "The file RS.EXE has an invalid signature. Installation cannot be continued. I have updated Win 7 64 but the problem continues. Another idea? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/01/2022 11:56:36New subject after splitting |
| 4/6/2022 1:40 PM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello which ALM Version do you have tried to install? (first you have to uninstall the old ALM Version) I would try latest Version: https://support.industry.siemens.com/cs/de/en/view/114358 Bye Murof |
| 10/4/2022 4:04 AM | |
Joined: 2/8/2017 Last visit: 4/9/2025 Posts: 2 Rating:
you need to extract all the files first. that fixes it |
| 10/4/2022 12:53 PM | |
Hello I would say its typical for the issue that is described in the Readme of the Upd2 in this Link: https://support.industry.siemens.com/cs/ww/en/view/109757233 Bye Murof |
| 6/25/2025 6:55 AM | |
Joined: 12/16/2024 Last visit: 9/29/2025 Posts: 2 Rating:
Why don't Siemens just fix that ? Why have we to search the forum for such 'stupid' solutions / tricks ? |
| 7/7/2025 1:42 PM | |
Hello As already written you should check the readme of Upd2 here we can read: "Signature error when starting the setup So a non up to date Windows Version could cause this issue also. Bye Murof |
Last edited by: Murof at: 07/07/2025 13:43:07If this Information really helps, you could use the Rate function |
