(0)| 10/7/2025 9:10 AM | |
Joined: 9/3/2024 Last visit: 10/9/2025 Posts: 3 Rating:
Hello, I have the same problem with an IOT2050 Advanced FS:01 what is the solution to solve this problem ? root@iot2050-debian:/mnt# cat /etc/os-release root@iot2050-debian:/mnt# dpkg -i iot2050-firmware-update_arm64.deb Best regards ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 10/07/2025 09:17:45New subject after splitting |
| 10/7/2025 12:56 PM | |
Joined: 3/12/2024 Last visit: 10/31/2025 Posts: 215 Rating:
Hello, you have the same issue as in the other post where your request was split from: IOT2050 Advanced FS:01 is delivered with Firmware version V1.0.1 → you first need to update this firmware version.
BR |
| 10/8/2025 3:18 PM | |
Hello Udae, In fact the problem is : I download python3-progress_1.5-1_all.deb from : Install it manually : sudo dpkg -i python3-progress_1.5-1_all.deb It solved the problem of "Package python3-progress is not installed" and the update became possible. Laurent |
| 10/9/2025 12:58 PM | |
Thanks for your helpful feedback! |
