(1)| 11/17/2025 3:28 PM | |
Joined: 4/28/2015 Last visit: 11/21/2025 Posts: 10961 Rating:
Hello, more cfg options are required to set correctly so I linked here some PDF about module cfg, diagnostic: Crevis NA-9122 DP Slave module manual The first idea was so you have wrong Slave address set on module rotary switches and same value at cfg on TIA. What is also missing at your screenshot is Rack and Slot value so you probably did cfg of module. |
With best regards... |
