(6)| 1/2/2026 12:34 PM | |
Joined: 7/30/2024 Last visit: 2/2/2026 Posts: 1229 Rating:
Hello Henry1675, thank you for the feedback. The system is setup in a way that redirects you to the new Forum, when you enter a classic Forum link as your first action. After that, it keeps you in the environment you are, so once you navigate to the classic forum, you will stay there if you open any links. You can set a page as your startpage, that has the redirection deactivated, for example: https://support.industry.siemens.com/forum/ If you open this page to login, you can then enter any link and it will open in the classic Forum environment. Kind regards, Moderator_Lan |
| 1/27/2026 5:54 AM | |
Joined: 10/3/2010 Last visit: 1/29/2026 Posts: 1573 Rating:
Just go back to the good old WORKING classic forum ASAP please. This sieportal is useless and at this point even the classic forum gives Bad gateway errors all the time. This doesn't even work now: https://support.industry.siemens.com/forum/ Bad Gateway The proxy server received an invalid response from an upstream server. The session timeout is also a pain in the… |
B r g d s , |
