2/5/2010 9:09 AM | |
Joined: 4/24/2006 Last visit: 10/18/2024 Posts: 8746 Rating: (1169)
Dear iboulay, What software did you use to programm panel? Please give us the exact version. Best regards, Wizard |
2/7/2010 2:06 PM | |
Joined: 5/28/2008 Last visit: 10/12/2024 Posts: 4515 Rating: (839) |
Hello iboulay, If the problem is in the hardware, i.e. the touch screen is deffective, then there will be no solution with this touch panel. In this case you have to buy another panel and make the programming again. The new panel will not TP070 because the product hae been cancelled from April 2008. http://support.automation.siemens.com/WW/view/en/4017022 If the program related to the software, then you will need to modify something in the panel software. TP070 configuration software is TP designer. With best regards, |
Ayman Elotaify |
