9/27/2010 8:46 AM | |
Joined: 8/30/2010 Last visit: 6/4/2024 Posts: 31 Rating: (1) |
Hello, What is the procedure for sending same message for three different numbers using MD720-3 modem with same transitions used in program.? Regards, Jeetendra Splitted from Different triggers for SMS using MD720-3. |
9/27/2010 9:02 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181) |
Hello, Using this FAQ: How can you send a text message (SMS) with SINAUT ST7? Just add 3 DBs with 3 numbers and into the program block SMS_Control (FB 124) call 3 times on the same conditions... Best regards, Hristo Mihalev |
9/27/2010 3:36 PM | |
Thanks, I am using MD720-3 with S7200. Then how to do this ? Regards, Jeetendra |
9/27/2010 5:01 PM | ||
In case of S7-200 look at MAS5 . You could use the same logic with MD720-3 instead of TC65.
best regards, Hristo Mihalev |
