Industry Online Support
12/6/2010 6:07 AM | |
Posts: 4 Rating: (0) |
There is rotary encoder connected to 216-2BD22-0XB0 to I0.0 AND I0.1 but I cannot see in cross ref file to check wheter the signal is processing. Please bear with ***ie question. Thanks Splitted from having some difficulties in finding the VW data so I can able to trace and check why the value is 0. |
12/6/2010 9:32 AM | |
Posts: 88 Rating: (2) |
your welcome. about the 2nd Q, i not quitly sure, never face with it probably HCO as you maintained. Best Regards, Greg. |
12/7/2010 2:16 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (713) |
See this topic: /tf/WW/en/Posts/51686#249915 |
Problem solved? |
12/8/2010 10:15 AM | |
Posts: 2930 Rating: (432)
Hi, you can use HC0 in the status table to see the value counting if it is HSC0. Hope this helps |
