Industry Online Support
4/18/2011 1:48 PM | |
Posts: 316 Rating: (37) |
Hi Jordi, I don't understand your questionexactly. Do you want to create your ohn telegramm with your own header? OR Do you only want to send data? If you want to send data you can use T_SEND and T_RCV. The data you want to send/recv you collect in a data area, which you send with the in_out "DATA"of the communication block T_SEND. On the other PLC you call the T_RCV. This block receives the data in the in_out "DATA". An interessting Link for you ;-): http://support.automation.siemens.com/WW/view/en/29737950 It'S an example for 300/400 PLCs but will also work bei 1200 plcs! |
4/18/2011 2:56 PM | |
Posts: 4 Rating: (0) |
Thank you very mych Have a nice day!!
