Industry Online Support
12/11/2011 12:32 PM | |
Posts: 27 Rating: (1) |
Hi all, I have fourquastions in my Issue. Iwant to programm the following HMI screen: KTP 600 basic color DP (6AV6 647-0AC11-3AX0) with winCC flexible 2008 [schnippschnapp] Second: I'm using the USB/PPI programming cable (6ES7 901-3DB30-0XA0).could i transfer (download) my .hmi program to: - KTP 600basic color(6AV6 647-0AC11-3AX0) ?? -What aboutTP 177 PN/DP (6AV6 642-0BA01-1AX1) ?? [schnippschnapp] other questions can be found in the following threads KTP 600 basic color DP and WinCC flexible 2008. Connect Panel to S7-200 Communication between Panel and S7-200 Thank you very much for taking time Best degards |
12/11/2011 3:26 PM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181) |
[schnippschnapp]
Yes, you can it with KTP600 basic color. For the other panel check it there Projecttransfer_V1_2_e.pdf. [schnippschnapp] Best regards, Hristo Mihalev |
