Industry Online Support
1/17/2012 10:04 AM | |
Posts: 1530 Rating:
Hello Sundar babu, I'm not eally an expert for Data Monitor, but if I take a look into manual, I think this (3.) will be solution. You may assign a xy.xls. Adding a date by your own every time you want to start a report will be a lot of effort, if you have got an event- or time triggered report. Maybe you can change name outside of WinCC with a batch file, which copies your data and changes name. Hoping your problem will be solved with this. Please let me know, just to help other users in same situation here in forum. Best regards Bizur |
2/2/2012 8:28 AM | |
Posts: 39 Rating:
hi, Sorry for late reply, I have gone through that document and configured the same thing as given. But no use. Is there anything we should do???
2/2/2012 5:47 PM | |
Posts: 1530 Rating:
Hello Sundar babu, how about sending me some attachments with your settings if FAQ did not help you? In the evening Icame acrossan FAQ, which could help you. Sorry, that I didn't find it earlier. How do you send WinCC/DataMonitor Reports by e-mail? How about sending me some attachments with your settings in case that FAQ did not help you? Best regards Bizur |
