4/20/2012 3:12 AM | |
Posts: 14 Rating: (2) |
I am using Simatic S7 - 300, CPU 315 - 2DP. There is no UTP connector, so what should i do for connect CPU to PC without MPI ? Thanks a lot |
4/20/2012 4:16 AM | |
Posts: 1064 Rating: (72) |
You could get a usb to mpi cable or if you have a pci slot available you could use a cp 5612 card |
4/20/2012 6:48 AM | |
Joined: 5/28/2008 Last visit: 5/11/2024 Posts: 4506 Rating: (836) |
Hello, PC adaptor cable is needed, MLFB:6ES7972-0CB20-0XA0. It's not an expensive solution. Please contact your local Siemens representative to provide you by a one. Hope this helps.
Ayman Elotaify |
4/23/2012 3:38 AM | |
OK the solultion is, I should be buy MPI cable from siemens |
