Industry Online Support
5/13/2012 9:20 PM | |
Posts: 2348 Rating:
Look carefully on pins on the backside of CPU - they shouldn't be bound or broken. Otherwise it will be hard to return it to Siemens. |
5/16/2012 8:15 PM | |
Posts: 559 Rating:
Any Update m.shoaib khatana, Is your problem solved? How? Please reply? |
5/18/2012 7:40 PM | |
Posts: 1064 Rating:
thats not good I don't think warrenty will cover that thanks for the reply and reason good luck witht the rest of the project |
5/20/2012 4:18 AM | |
Posts: 559 Rating:
Dear m.shoaib khatana, Actually this should be happen. I waould also suggest you to design panel in such a way that 24V Section & 230 V section should be different & coulour code for the wire also should be different. So one can do this mistake easily. |
