7/15/2013 9:01 AM | |
Posts: 22 Rating: (5) |
Hi dearSte39 Yes, with both SSL_IDs W#16#031C and W#16#011C, 8083 error code appears. I test other index numbers (1,2,3,4,5,7) for SSL_ID W#16#031C and they work good, but when I use the 8 index umber, this error code appears!
7/15/2013 9:24 AM | |
Joined: 1/21/2013 Last visit: 3/19/2024 Posts: 4618 Rating: (705) |
Hi ahmad_elec, as UMENCHO wrote what firmware version does your CPU? |
7/15/2013 9:36 AM | |
DearUMENCHO Version of my MC is 6. but properties of my CPU is : CPU 414-4H with firm ware 4.3. Do you say that the version of my CPU is lower for reding the serial number of MC? Please send me your source address. With regards
7/15/2013 9:47 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181)
Yes, the firmware version is not as required one. That info you can find at above mentioned FAQ andSIMATIC Fault-tolerant systems S7-400Has well. Best regards, Hristo Mihalev
7/15/2013 10:02 AM | |
Hi dearhdhosseini My CPU's properties is : CPU 414-4 H with firm ware 4.3. I used SFC 51 with SSL_ID W#16#031C and index W#16#0008 for read the serial number of MC from my CPU. I test the other SSL_IDs(11C,21C) but the result is same and the 8083 error code appears. Snapshot from my project is impossible for me, because it's location is so far from me! Thanks.
7/15/2013 2:11 PM | |
Joined: 11/21/2007 Last visit: 3/14/2024 Posts: 2323 Rating: (306) |
Hi ahmad_elec Here is a FAQ regarding upgrading Firmware of S7 400-H systems. http://support.automation.siemens.com/WW/view/en/42939944 May be of interest to you, if you want to check the possibility of upgrading the Firmware of your system Cheers Navnag |
There is no such thing as the last bug in a program |
7/16/2013 7:08 AM | |
HiUMENCHO I couldn't find what you say about firm ware version in the address, please give me a precise address. With regards
7/16/2013 7:19 AM | |
On page 66 from the manual. And from above mentioned FAQ in attachment. You can try itSupport Request. Best regards, Hristo Mihalev
