3/13/2014 8:21 AM | ||||
Joined: 10/11/2006 Last visit: 4/30/2024 Posts: 5827 Rating: (789)
Hello, there is an application: Axisfunctionblock SIMOTION Axis Function Block[Intranet]
Please contact your local siemens guy to provide you with this software. https://www.automation.siemens.com/aspa_app/contactmenu.aspx?ci=yes&HTTPS=REDIR®id=WW&lang=en&comptcid=o Solution
With best regards, |
3/13/2014 1:18 PM | |
Posts: 36 Rating: (2) |
This is whatI did. see attachment 1 and attachment 2 |
3/13/2014 1:24 PM | |
attachment 2 |
3/13/2014 1:38 PM | |
This is whatI currently use. (works but not great) |
3/13/2014 1:46 PM | |
Hello, no the axisfunctionblock is 1 block for all. PLC_Open is another thing. When you reach a software limit switch it is only possible to leave in the other direction or if an error occur check the reason and remedy by onlinehelp of the Scout. If you want a simple _jog, use _pos absolute with maxposition and _stop for stopping. Positive edge start _pos - negative edge start _stop command. It is easier to use ST for poscommands and variable declaration. |
