9/29/2014 3:46 AM | |
Posts: 70 Rating:
Hello my Expert, I want to ask about struct data in CFC, How to create struct data in CFC program? Thanks and best regard. |
9/29/2014 8:00 AM | |
Joined: 3/14/2008 Last visit: 7/12/2024 Posts: 2076 Rating:
You can access this in CFC editor at the toolbar choose: chart inputs/outputs. It'sa small icon. You can then link blocks to your struct or any other I/O by dragging the I/O to the block input/output. After this you can compile it as a block type. It means you can create logic in CFC and compile it as a complete block with all inputs/outputs you created. |
Last edited by: Oreca at: 9/29/2014 8:01 AMIf I could help you, you can use the RATE button. Thank you. |
