Industry Online Support
7/13/2006 4:59 PM | |
Posts: 3149 Rating:
did you already have a look at the transfer/compile-log file????? |
7/14/2006 10:59 AM | |
Posts: 4 Rating:
it ismessage from log, which apear aftercompilig WinCC server. |
7/14/2006 2:34 PM | |
Posts: 69 Rating:
Hi, for an undocumented error, contact the PCS 7 Hotline. Add the file transfer.log and a scrrenshott ofthe message. Use the following Link http://www.siemens.com/automation/csi_en_WW/support_request Balu |
11/14/2006 2:20 AM | |
Posts: 1 Rating:
Just wondering if you solved this problem and what the solution was. We have the same problem re error 12010 would appreciate any help |
11/14/2006 10:35 AM | |
Posts: 3149 Rating:
Hi, you should contact Simatic Customer Support... nemo |
11/24/2014 8:25 PM | |
Joined: 6/8/2013 Last visit: 5/15/2024 Posts: 158 Rating:
Dear Check the hardware configuration. in hardware configuration if pn networks name same the also you get same error.
