Industry Online Support
12/20/2014 8:05 AM | |
Joined: 1/28/2009 Last visit: 10/11/2024 Posts: 6852 Rating: (1365)
What type of timer you are using?For SIMATIC Timers, you can assign a 16-bit variable in form of global memeories (or even local with valid data) to set the Time value dynamically.You can find tricks for handling S5 Time data type here:
HD_S5TIMER data type L MW 100 // Integer contains seconds ITD L L#1000 *D // Time equivalent L T#55S // add a constant +D T #z CALL "TIM_S5TI" IN :=#z RET_VAL:=MW102 // final data to timer // call timer A I 0.0 L MW 102 SD T 1 NOP 0 I hope this helps, Hamid Hosseini |
